02-28-2023 01:49 AM
I'm experiencing a switch WS-C3650-24T reload with the last reason of "Power Failure" but there was no actual power issue.
3650#show version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.03E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 26-Aug-15 11:22 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 1.2, RELEASE SOFTWARE (P)
3650-sw1 uptime is 22 minutes
Uptime for this control processor is 24 minutes
System returned to ROM by Power Failure
System image file is "flash:packages.conf"
Last reload reason: Power Failure
cisco WS-C3650-24TD (MIPS) processor with 4194304K bytes of physical memory.
3 Virtual Ethernet interfaces
26 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
257008K bytes of Crash Files at crashinfo:.
1550272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
3650-sw1#show env all
Switch 1 FAN 1 is OK
Switch 1 FAN 2 is OK
Switch 1 FAN 3 is OK
FAN PS-1 is OK
FAN PS-2 is OK
Switch 1: SYSTEM TEMPERATURE is OK
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C2-250WAC DCB1924D15G OK Good Good 250
1B PWR-C2-250WAC DCB1913D3D0 OK Good Good 250
show logging
*Feb 28 04:00:38.630: envvar DC_COPY is not set
*Feb 28 04:00:15.610: *%INIT-7-SWITCH_BOOTING: 1 wcm: Switch booting...
*Feb 28 04:00:52.221: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Feb 28 04:00:52.221: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Feb 28 04:00:52.223: %NGWC_PLATFORM_FEP-6-FRU_PS_OIR: Switch 1: FRU power supply A inserted
*Feb 28 04:00:52.224: %NGWC_PLATFORM_FEP-6-FRU_PS_OIR: Switch 1: FRU power supply B inserted
*Feb 28 04:00:52.270: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Feb 28 04:00:54.518: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Feb 28 04:00:54.518: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Feb 28 04:00:56.649: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Feb 28 04:01:13.084: %SYS-5-LOG_CONFIG_CHANGE: Console logging: level emergencies, xml disabled, filtering disabled
*Feb 28 04:01:13.172: %SYS-6-CLOCKUPDATE: System clock has been updated from 04:01:13 UTC Tue Feb 28 2023 to 11:01:13 BKK Tue Feb 28 2023, configured from console by console.
*Feb 28 04:01:13.482: %SYS-5-CONFIG_I: Configured from memory by console
*Feb 28 04:01:13.529: %STACKMGR-6-ACTIVE_READY: 1 stack-mgr: Active switch 1 is ready. System has been configured
May I know if how to fix this issue?
Thank you,
02-28-2023 02:30 AM
are you sure there was no at least small disruption of power due to any reason? may be power fluctuate, power cable loos connection, or things like that?
02-28-2023 08:57 PM
No, there was no disruption of power at all.
