nokia wifi setting
rahulk4
how to configure cisco wifi setting in nokia s60?
arunepan
tap and hold the wi-fi network in the settings. The personalized settings will open up. Then select the proxy settings accordingly.
arunepan
you can try this way:-
menu > Tools > Settings > Connection > Access Points > Options > New access point
Change "Data bearer" to "Wirelsss LAN".
For "Access point name" use the hidden SSID and "Network status" must be "Hidden".
Hit also "Options" and check out the "Advanced settings", in case you need to change those, too.
may be this help.
rudrsaha
