API call for AP-provision
trondaker
Level 3
Level 3
Has anyone made this api-call work? Could you share the json-object being sent? I get the following no matter what i do:
Json sent:
ap_to_provision = [{
"rfProfile": "Some-radio-profile",
"siteId": "932d38c-6805-49b0-81b7-c2ec96d3b115",
"deviceName": "AP-Name-here",
"type": "Unified AP",
"siteNameHierarchy": "Site/name/to/floor"
I have tried the SiteID for the building and for the actual floor, same result. This call is sent via the DnaCenterAPISDK, and the URL is /dna/intent/api/v1/wireless/ap-provision.
Error message:
"bapiKey": "d897-19b8-47aa-a9c4",
"bapiName": "AP Provision",
"bapiExecutionId": "4bc3e6ce-cfb9-4f67-911f-5e64c8f8073f",
"timeDuration": 720,
"status": "FAILURE",
"bapiError": {
bapiErrorResponse : {
GET APwirelessConfiguration ","
bapiErrorCode " : "
bapiErrorMessage " : "
componentErrorResponse " : [ {"
compId " : "
uuid1b4f41c6 ","
compName " : "
Get site ID ","
compErrorCode " : "
400 ","
compErrorMessage " : "
Bad request in get Site ID BAPI ","
componentType " : "
BAPI_INVOKER "} ]}",
"runtimeInstanceId": "DNACP_Runtime_ff120c45-8d15-4ec3-a6e1-c74046c8d4c2"
I dont understand what other siteid i can try here? Should i claim the device first via the PnP-calls, and then provision? Version is 2.2.3.5.
trondaker
Level 3
Level 3
My bad, turns out the siteId here refers to the sitenamehierarchy for some odd reason.
"siteId": "Global/Building/Floor"
"siteNameHierarchy": "Global/Building/Floor"
Replace the actual ID of the site with the hierarchy of the floor the AP is on and its accepted.
trondaker
Level 3
Level 3
