Application Visibility issues
Karl Wilson
Hi Guys,
I have 2 switches that are showing CBAR related health issues that i don't know how to resolve.
Image attached, has anyone seen this before?
I have tried to reconfigure the switch\cbar but that  doesn't do much at all
Preston Chilcote
I think that first error explains all the rest.  Without a valid certificate the switch can't establish the https session to give data to Cisco DNA. Try using the Actions->Telemetry->Update Telemetry Settings workflow in Inventory.  Make sure to select "Force configuration Push" in the top of the popup.  That will reconfigure the certificate on the switches.
Preston Chilcote
Karl Wilson
Thanks the force didnt work but i disabled and re-enabled telemetry and enabled cbar without issue. Thank you
Great!  It occurred to me to put, in text, the error we are talking about so that google can find it and provide this advice to others:
"Device never communicated via HTTPS, threshold X minutes. Recommended to check that Cisco DNA Center certificate is installed on the device."
