Cisco DNA Center + 802.11r Fast Roaming, how to activate?
mdurupt
Hi Guys,
Well I would like to activate 802.11r for my corporate Wifi since our wlan card are compatible with fast-roaming.
Configuring this settigs, directly from my WLC9800 is pretty easy, you edit the WLAN, Enable Fast Transition and mark FT+802.1x
However, my whole WLC configuration is set with Cisco DNA Center.
How do you activate Fast Roaming using DNACenter? I am currently working with version 2.3.3.5
The only settings I have found is this but It seems not enough.
Many thanks for your help.
 For configuration not present on the network profile the only option I see if run cli template.
 You can take the commamd here
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/802-11r-bss-fast-transition.html
Hi Flavio,
Thank you for your answer. I have seen this solution but it's direct configuration into the WLC. If I do this, the configuration between DNA Center & WLC is going to be non-compliant.
Any solution directly from DNA Center?
