Cisco switch C9300X-12Y-E
joao-pereira1
Cisco switch C9300X-12Y-E supports “SFP-10G-LRM” for a 10Gb link over Multimode fiber OM1(62.5)) 220 meters?
Joseph W. Doherty
Cisco SFP-10G-LRM module
The Cisco 10GBASE-LRM Module supports link lengths of 220m on standard Fiber Distributed Data Interface (FDDI) grade Multimode Fiber (MMF). To make sure that specifications are met over FDDI-grade, OM1 and OM2 fibers, the transmitter should be coupled through a mode conditioning patch cord. No mode conditioning patch cord is required for applications over OM3 or OM4. For additional information on mode conditioning patch cord requirements please see: https://www.cisco.com/en/US/prod/collateral/modules/ps5455/product_bulletin_c25-530836.html.
The Cisco 10GBASE-LRM Module also supports link lengths of 300m on standard Single-Mode Fiber (SMF, G.652).
From: https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html#CiscoSFP10GLRMmodule
However, within Cisco's Optics-to-Device Compatibility Matrix (https://tmgmatrix.cisco.com/?dr=10&npid=4301), that SFP is not listed for any 9300 model except for:
8 Replies 8
ammahend
No, OM1 typically can support 10 Gigabit Ethernet at lengths of up to 33 meters.
-hope this helps-
Thank you for your ansewer.
joao-pereira1
Cisco switch C9300-24U-E with C9300-NM-8X network module supports SFP-10G-LRM for a 10G link over Multimode OM1 (62.5) 220 meters?
-hope this helps-
If the C9300-24U-E supports the C9300-NM-8X network module, and as as latter supports the SFP-10G-LRM, the answer should be yes.
BTW, the C9300X-12Y-E supports 25 Cisco optical transceivers, but again, the SFP-10G-LRM isn't listed as one of them.  However, there's a difference between supported and whether it will work or not.  Much like 3rd party optics, it may work just fine, but if you do have a problem with it, Cisco won't support it.
Thank you for your answer.
Joseph W. Doherty
