11-06-2022 09:22 AM
Hello all,
there seems to be a lot of discussion about if it is possible to connect a non sda capable switch to FE. I have found this post "Solved: Non sda switch connected to the fabric edge - Cisco Community" from which I understand that it is possible to connect a non-sda capable switch to FE, if you connect it to a "trunk/server" port on the FE.
Unfortunately I cannot find any other documentation that supports the above and all other related cisco documentation advises to use extended nodes.
If this solution is to work, I assume that all configuration should be added manually to the non-sda-capable switch. Does trustsec still work if all needed configuration is done on the switch? What about LISP? Does the FE share the information about the downstream end points to the Control Node?
Please advise, since the temp use of a non-sda switch seems to be a "quick fix" for urgent scenarios, at least until an Extended node or other FE is provisioned.
Katerina
Solved! Go to Solution.
11-07-2022 12:13 AM
11-07-2022 12:13 AM
11-08-2022 03:52 AM
Hi Jerome,
thank you so much for making things clear!
Best regards,
Katerina
