01-29-2018 06:13 PM - edited 03-08-2019 05:25 PM
I am wanting to create a guest wireless network with the following conditions.
My question is can this be accomplished using access points in flex-connect mode where existing AP will broadcast an additional SSID (Guest), with dhcp scope address on router for wireless clients and wireless guest clients accessing the Internet locally.
My goal is to get items 1 and 2 working successfully first before proceeding on to item 3 and implementing CMX connect and engage.
Any assistance is greatly appreciated.
01-30-2018 01:42 AM
Hi @DAVID
This is perfectly doable. You can get a guide and follow through. Post here any problem.
A good tips for you to start, you're gonna need Flexconnec ACL and this ACL needs to be applied on the AP directly or Flexconnec group.
Besides that, an SSID with web auth, flexconnec local switching, radius server and redirect URL.
-If I helped you somehow, please, rate it as useful.-
01-30-2018 05:51 AM
can you point me to any cisco docs which cover these areas?
01-30-2018 06:35 AM
Here we go:
01-30-2018 06:36 AM
Hi David,
the CVD will help a lot.
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Borderless_Networks/Unified_Access/CMX/CMX_Visitor.html
also you can check this brief document to help with the Flex ACL
https://support.cmxcisco.com/hc/en-us/articles/216598448-Set-Up-Cisco-CMX-Connect
