DNA / CAT Center template - any way to use siteNameHierarchy as variab
fulioyutagg
Season's greetings,
All is nearly in the title: in Catalyst Center, is there anyway to retreive the site name set in Network Hierrachy (siteNameHierarchy if using API calls) and use it in a template?
There are several systems variables to use, but none seems to provide the site name.
From what I recall, there isn't a direct system variable in Catalyst Center templates to retrieve the site name set in the Network Hierarchy (siteNameHierarchy in API calls).
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
