DNAC 2.2.3.4 & ISE 3.0p5 Integration Issue
Mike.Cifelli
Anyone aware of any bugs relating to DNAC 2.2.3.4 & ISE 3.0p5 integration?  Issue has appeared post ISE bundle upgrade end of last week.  Integration snippet from DNAC:
 DNAC System360 snippet status:
Debug Logs from DNAC for ISE integration:
$ magctl service logs -rf network-design | lql
| 0 | 2022-02-07 14:58:59,804 | ERROR | SimpleAsyncTaskExecutor-5 | | c.c.a.c.s.h.CreateAaaMessageHandler | Establish trust with ISE failed with exception || 1 | com.cisco.apicem.commonsettings.service.exception.DnaIseIntegrationException: Error response received from ISE (HTTP status code: 502).
$ magctl service logs -r pxgrid | grep ERROR
INFO | coIseServiceImpl-Worker-2 | | c.c.e.i.n.PxgridHealthNotifier | MaglevEvent : ID: SYSTEM_EXTERNAL_ISE_PXGRID, Name: ISE PxGrid Connection Status, Namespace: SystemRawEvent, Domain: Integrations, Subdomain: PxGrid, Type: SYSTEM, Category: ERROR, Context: ISE PxGrid, Description: ISE PxGrid Connection Status : DISCONNECTED : , InstanceId: f4f68539-20f2-4fa8-bfe3-6999f9d32a71, Source: ISE PxGrid, TenantId: SYS0, Version: 1.0.0, Severity: 1, TimeStamp: 1644122708492, Payload: {"event_payload":{"pxGridConnectionStatus":"DISCONNECTED","failureReason":"","iseIp":"XX.XX.XX.XX","hostname":"abcdefXX.XX.XX","eventType":"FAILURE"},"system_event":{"event":"Failure","tags":"PxGrid","event_instance_id":{"hostname":"abcdefXX.XX.XX","ip":"XX.XX.XX.XX"}}} |INFO | coIseServiceImpl-Worker-2 | | c.c.e.i.n.PxgridHealthNotifier | MaglevEvent : ID: SYSTEM_EXTERNAL_ISE_PXGRID, Name: ISE PxGrid Connection Status, Namespace: SystemRawEvent, Domain: Integrations, Subdomain: PxGrid, Type: SYSTEM, Category: ERROR, Context: ISE PxGrid, Description: ISE PxGrid Connection Status : DISCONNECTED : Connection failed., InstanceId: 9dcbd5cc-e184-456b-8584-f0a762b08fc1, Source: ISE PxGrid, TenantId: SYS0, Version: 1.0.0, Severity: 1, TimeStamp: 1644122708497, Payload: {"event_payload":{"pxGridConnectionStatus":"DISCONNECTED","failureReason":"Connection failed.","iseIp":"XX.XX.XX.XX","hostname":"abcdefXX.XX.XX","eventType":"FAILURE"},"system_event":{"event":"Failure","tags":"PxGrid","event_instance_id":{"hostname":"abcdefXX.XX.XX","ip":"XX.XX.XX.XX"}
I have tried removing the pxgrid client in ISE & restarting network-design via: $magctl service restart -d network-design, but the issue is still present.  Currently have a case open with TAC, but figured I would share here to see if anyone has any insight. TIA!
Mike.Cifelli
FYSA This ended up getting resolved after reloading the ISE nodes that are running the pxgrid service.  Quick fix was remove stale dnac clients in ISE, app stop ise/app start ise on respective nodes, & re-test integration with ISE from DNAC AAA server settings.
Mike.Cifelli
