DNAC and Meraki dashboard integration
reed
I have a DNAC lab and Meraki test lab setup. I integrated the Meraki into the DNA inventory via pass/user instead of APIkey(as this kept failing).  I am able to see the meraki devices that are in that dashboard but unable to see their names, they come up as "null".  Has anyone had issues with this or experience fixing it?
Gaur Samal
DNAC - Meraki integration should be done by API key method.
however, if you are doing it via user/pass method, and you can device IP address, but hostname are not shown, then most probably it is not able to sync with those devices.
you would probably want to open up a TAC case for investigation the issue.
sivathot
As of now it supports meraki dashbord api not individual devices below it. Meraki Wireless device support is on the road map, it will happen in future releases.
