DNAC integration and functionality check
sujanyakj
Hi All, Kindly suggest me on the below queries:
Can we onboard Juniper switches/firewalls in DNAC for Assurance and visibility?
Also what are the functionalities supported from DNAC for Meraki ?
Leo Laohoo
No.
DNAC Compatibility Matrix
Hi @Leo Laohoo ,
Thanks for the response. We are planning to deploy DNAC with recommended version 2.3.3.7 will it be compatible with Meraki Dashboard Integration. If yes , do we have any data sheet for the same , I found it for 2.3.5 version.
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/dna-center/nb-06-dna-center-data-sheet-cte-en.html
