DNAC onBoarding using csv
pholos
Hello everyone !
I'm trying to import a csv during the pnp to complete the template variables during tests. I exported the Excel from DNAC and filled the missing parts. However, I get the following error on DNAC.
This is what the Excel looks like.
Can anyone tell me what's wrong with it and how to solve this problem.
Thank you !
pieterh
are you by chance importing the EXCEL file ? instead of the .csv export of this excel ?
if not then it is exactly as the error say -> the format does not match
download the template .csv file an modify this with your information
I attached the default template from my version, but it may be different between versions
pholos
I was indeed importing the EXCEL file !
I'll try using the  .csv instead.
Thank you @pieterh
