Dnac - Switch snmp auth failure on reboot
Karl Wilson
Hi Guys,
Has anyone experienced a switch always loosing the snmp comms on a reboot via the dnac? The settings are still present on the network switch but i have to run a re-discover to fix the communication. NCIM12006 is the error code. once i do the re-discover it fixes the problem until its upgraded/rebooted.
9300lm running 17.9.5
dnac 2.3.5.5
Karl Wilson
ah... i think my snmp-server user is disappearing.... still testing
Hello Karl!
I had the same issue. The problem is in the switch itself and the version of the software. It's deleting the snmpv3 configuration...
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuw36080
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwe24431
BR
****Kindly rate all useful posts*****
Karl Wilson
Thanks Daniel, What version are you now running? 17.9.5 which im on should address both them bugs
I upgraded to 17.9.5 but it didn't fix my bug...
BR
