Do I need to Upgrade from DNAC to Catalyst Center ?
robad
We have DNAC, and I heard that it's now switched into 'Catalyst Center'
1. should I upgrade DNAC to Catalyst Center ?? is it just like upgrade DNAC to a newer version ?
2. I tried to see what is my current DNAC version, but can't see it via Software Management. I see some strange error that it can't connect to "ciscoconnectdna.com" , but I see that it's not a name that answers from anywhere .....
Do you know how to solve it ?
Can I see my current version via maglev CLI ?
thanks in advance !!
marce1000
  - On the first part of your question : 'Catalyst Center' is just a new naming of the product. If you are thinking of upgrading the product with whatever name used ; then for instance browse the Release Notes of the last or the version you want to upgrade to.
  - As far as the connection  to "ciscoconnectdna.com" is concerned ,make sure  you have (no) local firewalling solutions
    blocking this. This could for instance be tested by putting a laptop on the same subnet as your DNAC host and then testing
   this reachability too.
 M.
5 Replies 5
marce1000
 M.
robad
Hi Marce, thanks for your reply.
about question 1, I got it now - thanks !
Regarding question 2, I even don't have a ping to this name from my own laptop ..... I have no firewalls...
When giving ping from my laptop it can't resolve any IP .....
Do you have a ping from your own laptop to "ciscoconnectdna.com" ? or nslookup to it
        - No . but when looking at https://intodns.com/ciscoconnectdna.com   there is a www record for it
  which seems to be 'alive' ; not sure how this related to your problem.
 M.
   - You will find some details on the host with :  % nmap -A -P0 www.ciscoconnectdna.com
      If you intend to not read a book this evening (LOL!)
 M.
