12-26-2024 01:34 AM
Hi Team, can you confirm if the Cisco Business Switch 24T-4G have POE?
Solved! Go to Solution.
12-26-2024 02:10 AM - edited 12-26-2024 02:13 AM
12-26-2024 01:43 AM
It does not. You need the CBS350-24P-4G model.
Check the datasheet
12-26-2024 01:55 AM
Hi Sir Flavio,
Can we clarify this? Does CBS220-24T-4G supports POE? Because in this documentation (Cisco Business 220 Series Smart Switches Data Sheet - Cisco), under product specification, it tells us that this switch supports POE.
Thank you
12-26-2024 04:28 AM
