export serial number of all power supplies from DNAC
silso
is there a simple way to export the power supply SNs for each device out of DNAC without viewing every single device?
Thanks!
pieterh
I don't think there is a default report to do this.
but you can use the "command runner " to submit a command like
     show inventory | include PID
    show inventory | include AC-P
or  show inventory | include AC-P|C9300L (includes the switches SN if this is a C9300L series switch)
command to all (or selected) devices
you can export the output to a single file for all devices.
then you still need to do some post-formatting to remove unnecessary lines
Thanks for the reply! The third command is going to do it for me. But now I have the problem, that in Command Runner I have to choose every single device i want to run the command on (and there's over 400 of them). I believe there must be a better way, right?
We are currently running DNA-Center Version 2.3.5.4
