Extended Node Port assignment - for access points
lsakthiv
I have an design requirement where the fabric AP is connected with the Extended Node. And I need to "Add Port assignment for access point in SDA Fabric" through the API, but whenever I try to use these ("/dna/intent/api/v1/business/sda/hostonboarding/access-point" ) API for the port Assignment on the Extended Node i got the failed message "Could not find Edge device in SDA fabric with IP=x.y.z.x" - where i have given my Extended Node IP and interface name for Port assignment.
From that error my understanding is that I can only use that API for the Edge Device port assignment.
So my concern is that do we have any API support for the same process for the Extended nodes as well? because manually in the GUI I can do the port assignments for the both Extended nodes and Edges.
Is there any other way for Port Assignment for Access points in the Extended Nodes of SDA?
Thank you in advance.
0 Replies 0
