ezPM on ASR1001-x (DNA integration)?
AmbatiRaydu
I have difficulties when trying to provision DNAC to my router ASR1K-X, the provisioning is failed due to "no performance monitor context tesseract ^ % Invalid input detected at '^' marker.",
When i trying to configure manually ezPM in the router, there is no command for performance monitor inside the configure terminal.
I'm using ASR1001-X with IOS 17.3.3. Does anyone know what is the problem ?
Thanks in advance
willwetherman
Hi @AmbatiRaydu
This is most likely due to incorrect license/feature set on the ASR1K as you need to be running the adventerprise license to support ezPM.
Try changing the license boot level from ipbase to adventerprise and then try enabling application telemetry again
Hope that this helps
Will
