How to configure the amped extender by using setup.ampedwireless.com ?
wlesliew
If you wish to configure the settings of the extender network, you can use setup.ampedwirelss.com as the gateway to access it. You can always use the default IP address as the alternative here. Press the enter button and you will access the login page. Input the login credentials and hit enter. Makes sure that the login credentials entered are correct. If you need any help with the login or the setup process, just get in touch with our expert team in the end.
0 Replies 0
