how to get a report for running TLS version on switch from DNAc
Ahmed Tarek
Level 3
Level 3
hi all,
i need to get a report from DNAc for all switch and routers in my environment that use TLS version 1.1.
i can get this info from every switch it self.
is there any report for this info from DNAc it self?
pieterh
I don't think there is a default-report for this
but you can use the "command runner"
- select the switches in the inventory
- actions -> more -> command runner
- issue commands to display tls version
- you can export the output as a single file for all switches
pieterh
wonderful!
thanks a lot!
