how to set banner for switches or routers from cisco dna
Ahmed Tarek
Level 3
Level 3
hi all,i have 20 switches and 5 routers in my environment
how to set banner or message of the day via DNA instead of set banner one by one in switch or router
2 Accepted Solutions
PabMar
You can do so under Design - Network Settings
Hope that helps.
Regards.
PabMar
It will appear on all devices that you do the provision workflow.
MOTD banner is what's called. Same thing. The command is typically banner-motd
Regards.
PabMar
Hope that helps.
Regards.
thanks for your reply, but is that will appear in all my devices ? all switches and routers?
also pls can you describe what is the different of banner and motd?
PabMar
Regards.
Ahmed Tarek
Level 3
Level 3
thanks for your reply and support.
really appreciated!
