01-30-2025 02:07 PM
My company is current upgrading the IOS of our devices from the older version to the new version for the device using Cisco DNA Center. Some of our ISR routers have version level at 16.9.5. When we update the IOS to 17.9.5, the router goes into controller mode and technical intervention is needed to restore back to autonomous mode. Is there a way to upgrade these devices and have it remain in autonomous mode?
01-30-2025 02:38 PM
Are you guys loading the right IOS on the DNAC ? If you are not using SDWAN, you should use the IOS-XE not IOS-XE SDWAN version.
01-30-2025 04:27 PM
01-30-2025 04:50 PM
Sounds to me you are using sdwan imagens and thats why the Router is activating the controller mode
01-30-2025 06:56 PM
How is that possible? The latest IOS XE SD-WAN software is version 16.12.5(MD). I am using 17.9.5a .
02-22-2025 05:22 AM
Hi Keith did you find the root cause? Have you gone to the TAC?
02-22-2025 06:03 PM
