Nexus switch not learning the mac address with Macsec device
alon to
In my network, I have two Juniper switches that are connected by a Nexus switch that only acts as an L2 switch.
I cannot learn the Mac-Address when I run Mac-Sec on Juniper switches on the Nexus side. (pic1)
If I delete the Mac-Sec configuration in Juniper, I do learn the Mac-Address in Nexus (pic 2)
When I use a L2 switch from another vendor instead of Cisco Nexus, I learn the Mac-Address in both cases
What could be the problem? When mac-sec is enabled in Juniper switches
6 Replies 6
M02@rt37
Hello @alon to
Which model of Nexus, and which NX-os version ?
Thanks.
Best regards
cisco Nexus9000 C93180YC-FX
version 9.3(13)
Did you try ""macsec shutdown"" in NSK
MHM
I added the command but without success :
NEXUS-2# sh run | i macsec
feature macsec
macsec shutdown
NEXUS-2#
NEXUS-2# sh mac address-table interface Eth1/15
Legend:
* - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC
age - seconds since last seen,+ - primary entry using vPC Peer-Link,
(T) - True, (F) - False, C - ControlPlane MAC, ~ - vsan
VLAN MAC Address Type age Secure NTFY Ports
NEXUS-2#
Please @alon to share the output of that command:
#show license usage
Best regards
NEXUS-2# show license usage
Feature Ins Lic Status Expiry Date Comments
Count
ACI-STRG No - Unused -
ACI-AD-GF No - Unused -
ACI-AD-XF No - Unused -
ACI-ES-GF No - Unused -
ACI-ES-XF No - Unused -
ACI-AD-XF2 No - Unused -
ACI-ES-XF2 No - Unused -
ACI-SEC-GF No - Unused -
ACI-SEC-XF No - Unused -
ACI-SEC-XM No - Unused -
N9K_LIC_1G No - Unused -
VPN_FABRIC No - Unused -
ACI-STRG-GF No - Unused -
ACI-STRG-XF No - Unused -
NXOS_OE_PKG No - Unused -
FCOE_NPV_PKG No - Unused -
SECURITY_PKG No - Unused -
ACI-PREMIER-GF No - Unused -
ACI-PREMIER-XF No - Unused -
N9K_UPG_EX_10G No - Unused -
ACI-PREMIER-XF2 No - Unused -
NXOS-PREMIER-M4 No - Unused -
TP_SERVICES_PKG No - Unused -
NXOS-PREMIER-M816 No - Unused -
NXOS_ADVANTAGE_GF No - Unused -
NXOS_ADVANTAGE_M4 No - Unused -
NXOS_ADVANTAGE_XF No - Unused -
NXOS_ESSENTIALS_GF No - Unused -
NXOS_ESSENTIALS_M4 No - Unused -
NXOS_ESSENTIALS_XF No - Unused -
NXOS_ESSENTIALS_XM No - Unused -
SAN_ENTERPRISE_PKG No - Unused -
PORT_ACTIVATION_PKG No 0 Unused -
NETWORK_SERVICES_PKG No - Unused -
NXOS_ADVANTAGE_M8-16 No - Unused -
NXOS_ESSENTIALS_M8-16 No - Unused -
FC_PORT_ACTIVATION_PKG No 0 Unused -
LAN_ENTERPRISE_SERVICES_PKG No - Unused -
