Scalable Group in DNA
MajidShirzadeh
Is there any specific reason that I can not see Scalable group from ISE in policy dashboard ?
I have ISE and pxGrid active and available with green check mark however scalable group is not showing up.
Gaur Samal
Please check if the subscriber is online in ISE. If it is online, then please collect RCA and open up a TAC case.
Yes, it's online in pxGrid tab.
ammahend
can you share a snapshot of where you are not able to see SGTs ?
-hope this helps-
anantsiv
HI ,
Kindly open a TAC case , they can help you out with the solution
Ananth
