SD-Access vs Compact-Switches or 3rd Party
Daniel Schmidt
Hello
I have a customer, who is interested at SD-Access, but the customer had a fiber-to-desk-cabeling and had compact-Switches from a 3rd party vendor.
Is there any SD-Access-ready solution  to integrate or replace those compact switches ?
Greetings,
Daniel
Shawn Wargo
Hi Daniel.
Good question. Short answer: No.
For Cisco compact switches, we do have the concept of "fabric extension" (sometimes called "subtended") automation.
Compact switches are not capable of direct participation in the Cisco SD-Access fabric (as Fabric Edge nodes), but the Cisco DNA Center can automate the connections (Layer 2) between compact-switches and the Fabric Edge nodes. There is also a second option to use the PNP/ZTD application of DNA Center, to push a full configuration to the compact-switches.
For more information on SD-Access support for compact switches, refer to the following link: https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise-networks/software-defined-access/solution-overview-c22…
However, we do not currently support "fabric extension" automation for 3rd party compact switches. Similarly, the DNA Center PNP/ZTD application does not currently support 3rd party devices. We are investigating ZTD support for 3rd party devices, but nothing is committed.
5 Replies 5
Shawn Wargo
Hi Daniel.
Hello Shawn,
Thanks for the Information.
Can you give some more Information abourt the concept of "fabric extension" and limits (VLANs) usw. .
Daniel
In the upcoming release of DNA Center (1.1) we will support 3 types of Fabric Extension nodes:
1. Catalyst 3560 CX Series Switches
2. Cisco Digital Building Switches
3. Industrial Ethernet Switches (NEW)
With the initial (1.1) release, we will only support a single VLAN per Extension node.
* We will support mulitple VLANs in a later release.
You can read more about the overall SD-Access 1.0 solution here:
Software-Defined Access 1.0 Solution White Paper - Cisco
Hi Shawn,
Is this still true?
How we can connect a 3rd party switch to SDA fabric?
Is there any design doc about it?
it will be just a L2 extension? a trunk link connected to an edge sw (vlans)? what about the config and policy?
Thanks in advance!
AdamGordon
good question. bot no
