Some ports on C9200 Switch not passing traffic
jeffwill1345
We have a C9200L-48P-4X deployed. All of the gigabit ethernet interfaces are on one vlan. Most of the interfaces pass traffic just fine but there are at least 4 interfaces (that we know of) that don't pass traffic. All of the interfaces are configured exactly the same and none of them were shutdown or disabled. We first noticed an issue because the PCs connected to the affected interfaces couldn't connect to the domain. When we switched the interfaces that the PCs were connected to, they could connect to the domain with no issues. Any ideas as why this might be happening?
I've attached the interfaces from sh run. The affected interfaces are 25,27,28,30 but their configurations aren't any different than the others.
23 Replies 23
show spanning tree
are the port is FWD or BLK ?
show interface status
are the port is a-full a-speed and connect or not ?
MHM
jeffwill1345
The spanning tree shows FWD for all ports
The ports are on auto speed
show interface x/x accounting <<- if you see packets IN and OUT then the port forward the traffic
MHM
Hello @jeffwill1345 ,
can you provide the output of the show interface Gi x/y command of the interfaces that are not passing traffic?
Regards, LG
*** Please Rate All Helpful Responses ***
Leo Laohoo
What firmware is the switch on?
What is the uptime of the offending switch?
Is this switch part of a stack or standalone?
jeffwill1345
Thanks for the help everyone! We're going to be rebooting the switch. I'll let you guys know if the problem still occurs after that.
The switch will need to be cold-rebooted, i.  e.  power cable and power supplies will need to be removed.
Depending on the firmware version of the switch, this exercise will need to be performed every 6 months or when this same issue re-occurs.
stuart.pannell
Level 3
Level 3
Do we know if the reboot fixed this issue, I have some C9200L-48-4G switches that are experiencing the same issue, the ports that have stopped working were connected to the same devices (Paxton Net2 Plus door access controllers) they have been moved to other ports and are now working without issue. We have been troubleshooting with a laptop, it connects to the port that doesn't work and the port comes up/up connected and we can see the laptops MAC address in the switches MAC address-table, the laptop Arps out for DHCP and an address is provided however the laptop does not receive the IP address. ARP on the L3 device sees what would be the laptops IP and MAC address. Pings to/from the laptop fail to/from the L3 switch SVI for the vlan.
What firmware is the stack running on?
What is the uptime of the each individual member of the stack?
Perform a cold-reboot of the offending stack member having port issues.  NOTE:  Cold-reboot is removal of all power supplies (and power stacking cables) off the offending switch member until the PS stops spinning on it's own.  Put the power supplies back in and re-energize.
stuart.pannell
Level 3
Level 3
Just an update to this issue, I have performed a warm reboot on these switches which has brought the ports back in operation.
We are having similar issues with our C9200-48P and 24 port switches using Paxton Net2 door controllers. After a reboot, the port communication is fine but after a period of time, the port stops passing traffic. The time period before loss of communication can be as short as a few minutes to a few weeks. Shutting/no shutting the port does not resolve the issue. If you plug in a different device into the port, that port cannot communicate either. The port is effectively unusable until a reboot. Does anyone know of an internal debug command that can show what is happening to this port as we plug in a working PC or other device as the port tries to come up? Using FW 17.03.04b and 17.06.04
We call this behaviour "ghost port(s)" and there is a very long list of bugs that fits.  Three of the following combination can trigger this:
1.  Long uptime (years)
2.  Flapping interfaces
3.  Switches are in a stack
For the 'Ghost Port' behavior, do you have a list of more triggers?
In my case, the switches are standalone and not in a stack. When a port stops passing traffic, we move the device to the next available port. Eventually as we run out of good ports, we would have to reboot the affected switch to restore functionality of the 'ghost ports'. Some of the switches I'm having issues with have only been up since this year. So, there is no way to restore the port functionality without a reboot? Also, I have only been performing warm reboots. I will try the cold reboot in the future to see if the port(s) will function longer than a few days/weeks.
Are the ports in error-disable?
