Synology NAS automation data backup
AFlack20
Anyone ever use a synology nas for automation data backups? We are having trouble configuring the synology to work with DNA. We are running DSM 7.0.1-42218 on our synology RS1619xs+
Specifically having trouble with the server path configuration portion in DNA saying the path is not absolute.
An example of how to define the path may be helpful...
DNA version is 2.2.2.5
AFlack20
Got it!
For our instance we ended up using;
/volume1/DNA_Backup/
Although this worked great for our automation data backup (our first test backup of just dna without assurance data), when we added the NFS for assurance backup and re-ran (this time with the scope of all data) this caused the elasicsearch service to crash and halt the backup.
Hello, Did you manage to resolve this issue? Are you able to use the Synology NAS for the Assurance backup? I am currently looking into the best options for storing Assurance backups from DNAC and was hoping a Synology NAS would suit our needs as the Assurance Backup size is rather large at around 8TB!
Any lock with this?  "Remote server is not supported: Error running uname on remote server: Permission denied, please try again. ."
It's a bit frustrating....
