terms need to undersatnd in DNA
Ahmed Tarek
Level 3
Level 3
hi all,
i`m Biggenner with knowledge zero
there are some terms I need o understand in Cisco DNA,
what is the following:-
- fabric fundamental - Loop back - local loop - border edge - border node - fabric node - border router - cp router - fusion router - default border - fabric border - virtual network in DNA
I already make a search but I can`t link all the above terms with all, I need a little explanation as I'm confused for all of them.
thanks a lot in advance.
-what
you can use Cisco SDA CVD - design guide. Here is section for main fabric terminology, but you can go over the entire doc as well.
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-sda-design-guide.html#Roles_and_Terminology
HTH,
HTH,
thanks for your input, really appreciated
