Unpositioned clients on DNAC
ammahend
Unable to see clients on DNAC on floor map (see enclosed), has anyone encountered this ?
-hope this helps-
10 Replies 10
DominikPecak
Level 6
Level 6
Did you find the solution?
drouleau
My DNA center is sync with CMX. CMX sees the client and is able to place them on the floor. DNA reports that mostly all clients are "unpositionned"
blaberdia
I see this exact same thing when syncing with DNA Spaces. If I log into Spaces directly, the clients are placed normally but DNAC shows all clients as un-positioned.
I have the same behavior, some clients on DNA Center, all of them in DNA Spaces.
I opened a case on that same problem i am using DNA Spaces, and on DNA Center the client counts matches with DNA Spaces but DNA Center plots only a few clients. The case is still opened.
Sylvain_Che
Is it required to get CMX/DNA Spaces for the clients to be positioned on the maps?
Sylvain.
As far as I know, yes. I've been using CMX for a few years now. CMX is becoming obsolete, I am still stuck with it at this time but my understanding is that DNA Space will do the same and probably more but until I experience it myself, I can't tell you more. My advice, don't invest in CMX, look at DNA space.
Thank you
Donald
Don't forget, that if you want to use hyperlocation you will need CMX on-prem for calculations.
SilentKeystroke
Did anyone ever find a resolution for this?
