Visio Icon for DNAC
parag_waghmare
I need visio icon for DNAC. where can I get it from. could not find on cisco visio stencil page,.
10 Replies 10
loverbey
I have requested that this get posted to https://www.cisco.com/c/en/us/products/visio-stencil-listing.html.  I'll update when it is posted, but also suggest to check early next week.
Hey, any update on the DNAC Stencils? Looking for physical icons (for latest 2019 hardware) and logical icons
I've reached out to Marketing again.  Hope to have an update for you soon.
Farhan Mohamed
I would request you to please follow this page, Link is : https://www.cisco.com/c/en/us/about/brand-center/network-topology-icons.html. If you are not able to find icon you are looking for BU will be updating it so you can find it sooner.
Hi community.
No, they are not there.
I am looking for Visio Stencils for c9800, DNAC, AP4800 and brand new c9100 APs but they are not there. We are unable to create the Visio draw for the deployment (physical connnections).
How does Cisco think we are gonna do it? Why not releasing Visio Stencils after product release?
Cheers
Agreed, how am I to help sell their product to my CIO and CTO with images.....
I used the above page. ISE can be found under Security. For DNAC I just used a server Icon from the Servers section. ISE and DNAC use the same form factor box. If you're creating a rack elevation diagram using the server Icons should be fine (at least for now). I just checked and do not see any updates from the BU.
Hope this helps,
Chuck
I also just did a "Make a wish" via DNAC. If others do the same thing then, in theory, they can prioritize this effort based on desire of the current customers.
Chuck
ahaskin
Why would you not use the Cisco UCS C220 M5 stencil that is what the hardware platform is ?
dan.renfro
I haven't found one yet.  I am using the Prime-NCS stencil in found in the wireless pack.
