WOL issue with C9500
Mahmoud Naser
hello evryone,
i have an issue with WOL on c9500
i have configured everything as shown
and i am using Kaspersky as wol server with ip add 10.40.170.175
my problem is
when i try to wake up the device did not respond
but if i forced to turn it on and try again to turn it off using wol server it is working fine
after one hour or more sometime less when the pc is off and try to wake it up again with wol server pc did not respond
i cannot find any logs for this issue
what should i do and how to fix this issue?
thanks for your support.
interface Vlan114
description NGU-BLD-D_3_114_4097_8207
ip address 10.44.114.1 255.255.255.0
ip directed-broadcast 101
ip network-broadcast 101
ip access-list extended 101
30 permit udp any any
40 permit udp host 10.40.170.175 any eq discard
40 permit udp host 10.40.170.175 any eq echo
15 Replies 15
I will share info to Mr @Mahmoud Naser and I will also share it with you.
MHM
