Cisco CLI Analyzer 3.4.0 side-by-side comparisons of console sessions Not working
BuddyAllison
Level 4
Level 4
CLI Analyzer window, allowing side-by-side comparisons of console sessions. not working - followinng the video sample but not having any luck? tried two defferant sessions to same IP & defferiant IP box - never got side-by-side windows? Help
kevwilso
Hi BuddyAllison,
CLI Analyzer allows you to open separate console windows.  After which you can manually or use OS specific functions to arrange your windows.  For example, in Windows, you can use Aero Snap. I think Microsoft built that into 7, 8, and 10. In macOS, you can use split view (https://support.apple.com/en-us/HT204948)
Kevin W.
