CLI Analyzer 3.6.5 upgrade
ng911ng911
Community Member
The windows upgrade to 3.6.5 keeps running into a weird error that it can't access the nw.exe file which is clearly in their folder structure. The install fails each time. Anyone else is experiencing this problem?
jofrumki
You may want to try a fresh install in this case, uninstalling first may also be necessary.
jllenhart
Community Member
Rolling in another 3.6.5 upgrade issue as an FYI.
On Windows 10 1909 the upgrade ran fine with version 3.6.5 replacing version 3.6.4 as expected.  On Windows Server 2012 R2 the upgrade (prompted from with Analyzer 3.6.4 itself) installed as an additional version, so both were showing in Programs and Features.  When that was true the application wouldn't open but you could see multiple related processes in Task Manager.  Uninstalling version 3.6.4 fixed it.  No need to re-install 3.6.5.
Johnny Lee
