CLI Analyzer 3.7.3 - Slow
besart-rexhepi
Level 4
Level 4
Why is CLI Analyzer so slow when opening new SSH connections?
Then when you are connected It also feels like there is a bit of input lag.
Is there something I am doing wrong or is it like that for everyone?
balaji.bandi
It's been a long time since I used the CLI analyser.
Do you think the ping to the device is all good? Can you check whether it's the same slowness you encountered when you connected via PuTTY or another SSH client?
Could you check the system for any antivirus software and disable it to test?
BB
It's the connection that takes a long time. Once I'm in, everything works as it should.
If I use Putty, it connects just as quickly with Telnet as with SSH
BB
