Showing results forĀ
Search instead forĀ
Did you mean:Ā
CLI Analyzer does not work with certain IOS-XR platforms
sreenivasgajula
Level 2
Level 2
Hello!
CLI Analyzer runs a few initial show commands when you ssh into a device, however, those sequence of commands cause the program to exit out of NCS540 devices since it's cli hierarchy is a little different from other IOS-XR devices like ASR9k.
I couldn't find a way to change the behavior and not lose the cool stuff that cli analyzer does with outputs from show commands.
ā€ƒ
jm583q
Frequent Visitor
Frequent Visitor
Have the same problem with ncs540
ā€‹ā€Œ
ā€‹ā€Œ
Determining Device Type, Model, Version, and Serial Number:
ā€‹ā€Œ
ā€‹ā€Œ
Running "show version" ...
ā€‹ā€Œ
Running "admin" ...
ā€‹ā€Œ
Running "show diag chassis" ...
ā€‹ā€Œ
Running "exit" ...
jm583q
Frequent Visitor
Frequent Visitor
I found is possible to use it if you chose in settings "No Cisco device" prompt works fine but no possible to use all CLI options
joshvisk
Community Member
@jm583q....this was extremely helpful!!  Now, I can at least log into the box without the recognition script kicking me out due to the "exit" command.  It was driving me crazy!
