03-09-2023 02:19 PM
Error shown in logs of ISR4321-K9, Version 16.06.04, when trying to use CLI-Analyser to SSH into it ...
Mar 9 20:32:45.675: %SSH-3-NO_MATCH: No matching kex algorithm found: client curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256 server diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
ISR4321-K9#sh ip ssh
SSH Enabled - version 1.99
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 1
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-(!! obfuscated !!)
ssh-rsa (!! obfuscated !!)
Is this because CLI-analyzer is missing ciphers?
Must I update from SSH 1.99 to SSH 2.0 ?
Please fix this ASAP? May you please inform me here that this is fixed?
Thank you!
Solved! Go to Solution.
03-09-2023 02:44 PM - edited 03-09-2023 02:47 PM
as i suggested another post - you have a cipher mismatch
read this log correctly :
EDIT: IOS XE 16.6 is an old code try to upgrade to 17.X
03-09-2023 02:49 PM
Wait .... The error message means the SSH client is not Deffie-Hellman but the router is expecting DH.
This is not a code issue, this is an issue with the SSH client-side.
03-10-2023 03:50 AM
I was not suggesting to upgrade IOS due to this issue, since i saw old IOS, so suggesting to upgrade to latest.
03-10-2023 07:54 AM
It surprises me that a mainstream commercial SSH client would have this issue.
Shouldn't a commercial SSH client just hold every reasonable cypher preference a mainstream box might require, such as diffie-hellman-group-exchange-sha1, and diffie-hellman-group14-sha1 ?
03-10-2023 03:42 PM
I am using SecureCRT and DH is disabled by default. If I see a message like that, I usually just put a tick in the SSH option for DH and it starts working.
03-11-2023 02:45 AM
Due to security reasons some of the old ciphers fade (one side people asking to move to the next level of security, once asking legacy cipher in the network ) - so one needs to make a decision on what needs to be used for their use case.
As I mentioned earlier in another post - the CLI analyzer stopped releasing a new version, and it ended in 2021
I have also suggested some steps they recommend to ignore the options in the CLI analyser - have you tried them?
(Note : I do not remember, there is some where option you can do, but try to download cli analyser - giving me error - will try again and let you know if I come across any findings)
