CLI Analyzer does not work with certain IOS-XR platforms
sreenivasgajula
Level 2
Level 2
Hello!
CLI Analyzer runs a few initial show commands when you ssh into a device, however, those sequence of commands cause the program to exit out of NCS540 devices since it's cli hierarchy is a little different from other IOS-XR devices like ASR9k.
I couldn't find a way to change the behavior and not lose the cool stuff that cli analyzer does with outputs from show commands.
jm583q
Frequent Visitor
Frequent Visitor
Have the same problem with ncs540
Determining Device Type, Model, Version, and Serial Number:
Running "show version" ...
Running "admin" ...
Running "show diag chassis" ...
Running "exit" ...
jm583q
Frequent Visitor
Frequent Visitor
I found is possible to use it if you chose in settings "No Cisco device" prompt works fine but no possible to use all CLI options
joshvisk
Community Member
@jm583q....this was extremely helpful!!  Now, I can at least log into the box without the recognition script kicking me out due to the "exit" command.  It was driving me crazy!
