CLI Analyzer is crashing after macOS Big Sur upgrade
sayamash
I'm using CLI Analyzer 3.6.6 with Macbook Pro. After upgrade to macOS Bir Sur 11.1, the app is frequently crashing.. Is it known bug? How can I report it to dev team?
Satoshi
Francesco Molino
People using this latest version on BigSur have the issue.
A new release should come soon:
https://community.cisco.com/t5/cisco-cli-analyzer-documents/v3-6-6-crashing-often-on-macos-big-sur/ta-p/4189393
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
thank you!
You're welcome
Francesco
