CLI Analyzer Supported Devices
Mohsin_Mohamed
Frequent Visitor
Frequent Visitor
I am trying to understand about the products supported for analysis on the Cisco CLI Analyzer.
As stated on the product page, various other platforms such as UCS, Firepower, Security Appliances are supported alongside the NXOS and IOS XE XR.
I have performed some support files downloads from UCS and Firepower and have followed the same steps as I would normally do for the NXOS.
After uploading the gz files, the analyze process runs for sometime and afterwards prompted with "file not supported".
Is there another format that I should specify for the other platforms or does the CLI analyzer use a different analysis method for different products?
Appreciate the support in advance.
Thank you.
0 Replies 0
