Unable to launch Cisco CLI Analyzer 3.6.8 on Monterey
jcraven1
While attempting to launch Cisco CLI Analyzer 3.6.8 on Monterey, the app bounces a couple times in the dock and then dies. I've tried deleting the app and settings in ~/Library, but still have issues. It appears to be some permission issue with MacOS sandbox rules, but not 100% sure. Launching from the CLI gives stack trace. On a whim, I decided to try it with sudo and it does work.
  ~ /Applications/Cisco\ CLI\ Analyzer.app/Contents/MacOS/nwjs
[Error: ENOENT: no such file or directory, stat '/Applications/Cisco CLI Analyzer.app/Contents/Resources/app.nw/chh/ucs.CHH.txt.gz'] {
  errno: -2,
  code: 'ENOENT',
  syscall: 'stat',
  path: '/Applications/Cisco CLI Analyzer.app/Contents/Resources/app.nw/chh/ucs.CHH.txt.gz'
Received signal 6
 [0x000117ac1809]
 [0x000117a162b3]
 [0x000117ac1631]
 [0x7ff81be16e2d]
 [0x7fd5e351e250]
 [0x7ff81bd4dd10]
 [0x00011d39b798]
 [0x00011d39b39b]
 [0x00011d39b315]
 [0x000117a0b6a8]
 [0x000117a0b670]
 [0x000117a0ce76]
 [0x00011ae2fbd8]
 [0x00011ae31129]
 [0x00011ae1f0b2]
 [0x0001161b897c]
 [0x0001161b85d8]
 [0x0001161e07a9]
 [0x0001161e0504]
 [0x0001161e030e]
 [0x00011a9b642d]
 [0x000115e5badd]
 [0x000115cd160e]
 [0x000118a23b7e]
 [0x000117a7b5a8]
 [0x000117a8ec61]
 [0x000117a8e93a]
 [0x000117ad4927]
 [0x000117acefc2]
 [0x000117ad434f]
 [0x7ff81bec884d]
 [0x7ff81bec87b5]
 [0x7ff81bec8534]
 [0x7ff81bec6f6b]
 [0x7ff81bec652d]
 [0x7ff824ae43e1]
 [0x7ff824ae4137]
 [0x7ff824ae3ed5]
 [0x7ff81e8f18f0]
 [0x7ff81e8eff5c]
 [0x000118028a00]
 [0x000117acefc2]
 [0x000118028939]
 [0x7ff81e8e2359]
 [0x000117ad501c]
 [0x000117ad3e3c]
 [0x000117a8f2ab]
 [0x000117a5a01b]
 [0x000117c78a9b]
 [0x000115945455]
 [0x000115946e82]
 [0x000115942b11]
 [0x0001179c3753]
 [0x0001179c32c3]
 [0x0001179c1ab9]
 [0x0001179c234c]
 [0x00011476f567]
 [0x000105d239bf]
 [0x000109ddc4fe]
 [0x000000000000]
 [0x000105d20000]
[end of stack trace]
[1214/094957.463433:WARNING:crash_report_exception_handler.cc(240)] UniversalExceptionRaise: (os/kern) failure (5)
[1]    72955 abort      /Applications/Cisco\ CLI\ Analyzer.app/Contents/MacOS/nwjs
(node:72987) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
debug: (re)disabling spelling service, currently enabled: true
debug: (re)disabling password saving, currently enabled: true
debug: (re)disabling alternate error pages, currently enabled: true
debug: (re)disabling autofill, currently enabled: true
debug: (re)disabling safe browsing extended reporting, currently enabled: false
debug: (re)disabling search suggest, currently enabled: true
debug: (re)disabling translation service, currently enabled: true
  ~ sudo /Applications/Cisco\ CLI\ Analyzer.app/Contents/MacOS/nwjs &
[1] 73066
  ~ [Error: ENOENT: no such file or directory, stat '/Applications/Cisco CLI Analyzer.app/Contents/Resources/app.nw/chh/ucs.CHH.txt.gz'] {
  errno: -2,
  code: 'ENOENT',
  syscall: 'stat',
(node:73100) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
debug: (re)disabling spelling service, currently enabled: false
debug: (re)disabling password saving, currently enabled: false
debug: (re)disabling alternate error pages, currently enabled: false
debug: (re)disabling autofill, currently enabled: false
debug: (re)disabling search suggest, currently enabled: false
debug: (re)disabling translation service, currently enabled: false
debug: disabled spelling service
debug: disabled password saving
debug: disabled alternate error pages
debug: disabled autofill
debug: disabled safe browsing extended reporting
debug: disabled search suggest
debug: disabled translation service
info: Starting processing of CHH files at: 1639493403350
info: Parsing CHH file: ios.CHH.txt.gz
info: Parsing CHH file: nx-os.CHH.txt.gz
info: Parsing CHH file: asa.CHH.txt.gz
info: Parsing CHH file: wlc.CHH.txt.gz
info: Parsing CHH file: ucs.CHH.txt.gz
info: Parsing CHH file: ucs-b.CHH.txt.gz
info: Parsing CHH file: ios-xr.CHH.txt.gz
debug: Cleaning up temp directory
"PortInfo.comName" has been deprecated. You should now use "PortInfo.path". The property will be removed in the next major release.
info: Completed processing of CHH files at: 1639493404991, total time: 1.641s
info: CHH (ucs): Version 1485895505 successfully loaded
info: CHH (ucs-b): Version 1485895505 successfully loaded
info: CHH (wlc): Version 1504107287 successfully loaded
info: CHH (nx-os): Version 1523436743 successfully loaded
info: CHH (asa): Version 1554746084 successfully loaded
info: CHH (ios): Version 1556004756 successfully loaded
info: CHH (ios-xr): Version 1524299504 successfully loaded
ELIAS AGGELIDIS
Dear Team ,
try this
"sudo /Applications/Cisco\ CLI\ Analyzer.app/Contents/MacOS/nwjs"
Even after this Syntax being used, the application starts but its very limited.
is there a fix on the way or not?
Is there any chance that a native Mac version (aka Universal macOS Binary) will be released?
The current v3.6.8 is still based on the x86_64 architecture and relies on Rosetta 2, the built-in dynamic binary translator, to work on the current Apple Silicon Macs.
