Is Cisco CLI Analyzer still supported?
lwestman
Frequent Visitor
Frequent Visitor
I have been Cisco CLI Analyzer for the past year or two and today I was trying to figure out if I can launch connections using command line due to our company starting to use a Privilege Access Management software. The software supports custom launchers that can be launched via command line. It comes with a launcher for putty by default and works well. When trying to look up help information for CLI Analyzer the page doesn't exist anymore
mrkaufman
Initiate Session via Launch Arguments
This feature allows the user to launch the CLI Analyzer from the command line and trigger initiation of a SSH or Telnet session. Hostname/IP is required with optional username. See the below for Windows and OS X examples:
> C:\Program Files\Cisco Systems, Inc\Cisco CLI Analyzer\nw.exe "--ssh lab123@172.18.94.56"
> C:\Program Files\Cisco Systems, Inc\Cisco CLI Analyzer\nw.exe "--ssh 172.18.94.56"
# open /Applications/Cisco\ CLI\ Analyzer.app --args "--ssh lab123@172.18.94.56"
# open /Applications/Cisco\ CLI\ Analyzer.app --args "--ssh 172.18.94.56"
mrkaufman
