using python SDK
achan2012
Community Member
I am new to UCS platform. I have been trying out the different programming interfaces to Cisco UCS XML API.
I am trying to get the Cisco Python SDK to work and running into the roadblocks.
i installed by running python3 setup.py install.
I followed the simple script in the documentation.
from UcsSdk import *
if __name__ == "__main__":
     handle = UcsHandle()
     handle.Login("10.7.193.10","mon","mon")
     handle.Logout()
The error i am getting is:
Traceback (most recent calls last):
   File "./testucs.py", lin 3, in <module>
  File "/usr/local/lib/python3.3/dist-packages/UcsSdk/__init__.py", line 1, in <module>
          from MoMeta import _VersionMeda,_ManagedObjectMeta
ImportError: No module named 'MoMeta'
I can see MoMeta.py package in /usr/local/lib/python3.3/dist-packages/UcsSdk
I am running Ubuntu 13.04 with Python 3.3
Has anyone encountered this issue?
reswaran
Hi Allen,
UCS SDK is compatible only with Python 2.x. There are lot of fundamental changes in python 3.x which breaks backward compatibility. More details on http://docs.python.org/3/whatsnew/3.0.html
SDK for python 3.x is in the plan. But we don't have any timeline yet.
Ravikumar
reswaran
Hi Allen,
Ravikumar
Cisco UCS X-Series Energy Efficiency Offer
