Cisco Developed UCS Integrations Knowledge Base
Field Notice 70545
Knowledge Base Articles
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions.Cisco UCS PowerTool Core modules are develope...
rarausha by Cisco Employee
  • 181 Views
  • 0 comments
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core modules are develop...
  • 231 Views
  • 0 comments
  • 317 Views
  • 0 comments
Cisco has released the 4.0(0) version of the Cisco UCS Manager VMware vSphere HTML remote client plugin. The UCS Manager vSphere HTML client plugin enables a virtualization administrator to view, manage, and monitor Cisco UCS physical infrastructure....
Reg.PNG Screen Shot 2018-09-28 at 4.14.11 PM.png Screen Shot 2018-09-28 at 4.15.00 PM.png Screen Shot 2018-09-28 at 4.16.19 PM.png
dsoper by Cisco Employee
  • 30542 Views
  • 25 comments
  • 6 Helpful votes
  • 361 Views
  • 0 comments
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC, Cisco UCS Common and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool Core m...
  • 574 Views
  • 0 comments
  • 601 Views
  • 0 comments
aapatwa by Cisco Employee
  • 544 Views
  • 0 comments
asagade by Cisco Employee
  • 764 Views
  • 0 comments
  • 563 Views
  • 0 comments
  • 808 Views
  • 0 comments
  • 685 Views
  • 0 comments
Cisco UCS PowerTool Suite is a set of PowerShell modules for Cisco UCS Manager, Cisco IMC, and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions. Cisco UCS PowerTool modules are developed using the ....
  • 1155 Views
  • 0 comments
This script automates the upgrade of UCS Manager firmware (logging into CCO, downloading firmware bundles to a local working directory, uploading bundles to the target UCS System and walking through all steps of the upgrade, including creation/assign...
ericwill by Cisco Employee
  • 20387 Views
  • 23 comments
  • 6 Helpful votes
Purpose of script: This script collects metric count data from your ACI fabric using REST API calls and saves it to an Excel file on the local computer. It requires a CSV file as input, containing the IPs, usernames, passwords, and Fabric Names of th...
keytyler by Cisco Employee
  • 735 Views
  • 0 comments
Top Contributors
