jomcdono
Installation:
  •      Using pip:
     pip install imcsdk
  •      Using Github:
     Install pip (skip if pip is already available):
          wget https://bootstrap.pypa.io/get-pip.py
          python get-pip.py
     git clone https://github.com/CiscoUcs/imcsdk.git
     cd imcsdksdk
     make install
Uninstall:
     pip uninstall imcsdk
Documentation:
     http://imcsdk.readthedocs.io
Features:
0.9.5 (2018-08-24)
  • Fixed an issue with missed requirement files
  • Added Python 3.6,3.7 to package meta
0.9.4 (2018-08-24)
  • Support for Python3
0.9.3.1 (2018-05-27)
  • Support for more APIs
  • Misc bug fixes
0.9.3.0 (2017-09-19)
  • Adds support for IMC version 3.0(2b), 3.0(3a) and 3.1(1d)
  • Adds support for HX platform
  • Fixes sync_mo
  • Containerizes imcsdk support for CIMC 3.0 using Docker
  • Adds context manager support for ImcHandle
  • Redesigned APIs for the following,
    • BIOS
    • Boot Order
    • Certificate
    • KVM
    • LDAP
    • NTP
    • SNMP
    • SOL
    • Syslog
    • Storage
    • vMedia
0.9.2.0 (2017-02-10)
  • Adds support for IMC version 3.0(1c)
  • New APIs for the following,
    • Secure Drive Encryption
    • BIOS Profile
    • Native Hardware Inventory Collection
    • Enable Redfish support
    • LDAP
    • NTP
    • IP Filtering
    • IP Blocking
    • Asset Tagging
    • SNMP Traps and users
    • Local Users
    • Adaptor operations
    • KVM/Sol/Vmedia operations
    • Power Budgeting and Power Capping
    • Boot Order Precision and Legacy Boot order
  • Improved local inventory collection API; handles multiple IMC servers and supports multiple output formats
  • Support for skipping attributes of a Managed object not known to a server version
  • Support for handling of interim/spin builds
  • Bug fix in monitoring firmware upgrade API
  • Bug fix in handle.query_children API when class_id and hierarchy are specified
  • Improved test Coverage
0.9.1.0 (2016-11-25)
  • Support for Modular C3260 and Classic platforms
  • Supports every Managed Object exposed by IMC upto version 2.0(13e)
  • Support to invoke APIs on individual server modules in case of C3260 platform
  • Support for TLSv1.1/v1.2 and fallback to TLSv1 for older versions
  • Support to filter out non-applicable properties based on the C-series platform
  • Validation of Managed Object version with the C-series version for better error-handling
0.9.0.3 (2016-08-25)
  • Added APIs layer to the sdk
0.9.0.1 (2016-08-25)
  • Fixed an issue with pip install
0.9.0.0 (2016-08-25)
  • Python SDK for IMC rack server management and related automation
  • APIs for CRUD operations simplified
  • Runtime memory usage is reduced
  • Nosetests for unit testing
  • Samples directory for more real world use cases
  • Integrating the sphinx framework for documentation
  • PEP8 Compliance
Przemekms
Frequent Visitor
Frequent Visitor
Is this project still maintained?
lequangmkp36
Community Member
whether you choose dynamic or static pages, the key to SEO success is providing valuable content, optimizing for local search, and following best practices. Both dynamic and static pages can rank well if properly optimized, so choose the approach that best suits your content management needs and your ability to maintain and update the pages regularly.  qr code
