ericwill
End of Support Notice: Support for the Flex-based Plugin for VMware vSphere has been discontinued.  The HTML based Plugin is recommended as a replacement.
Previous Release Information:
Cisco UCS Manager Plugin is an extension for the vSphere Web Client. It enables virtualization administrators to view, manage and monitor various aspects of Cisco UCS physical infrastructure. The result is a single pane of glass for Virtual Center users to get both physical and virtual infrastructure information for a given hypervisor.
New Features in UCS Manager Plugin 2.0(3):
  • Defect fixes
Supported vSphere Web Client Releases:
  • vSphere Web Client 5.5
  • vSphere Web Client 6.0
  • vSphere Web Client 6.5
Refer to release notes and user guide for more details.
reswaran
It’s the same. We just moved it from communities to cisco.com.
senthil andavan
Hi reswaran,
Found the logs. copied the logs when i try to launch the KVM
[2014-12-22 14:55:01.688] INFO  [INFO ] http-bio-9443-exec-1          com.cisco.ucs.vcplugin.service.UcsServiceBase                     getUcsHandle for uuid:
[2014-12-22 14:55:01.688] INFO  [INFO ] http-bio-9443-exec-1          com.cisco.ucs.vcplugin.service.MethodFactoryWrapper               UCSM SERVICE CALL:getKvmUrl
[2014-12-22 14:55:01.688] INFO  [INFO ] http-bio-9443-exec-1          com.cisco.ucs.vcplugin.service.MethodFactoryWrapper                UCSM REQUEST getConfigResolveClasses: dn= sys/chassis-1/blade-1,arg2= 2
[2014-12-22 14:55:01.844] INFO  [INFO ] http-bio-9443-exec-1          com.cisco.ucs.vcplugin.service.MethodFactoryWrapper               UCSM REQUEST SUCCESS, RESPONSE: 0024888557057399117775186907701924899160348931
[2014-12-22 14:55:01.844] INFO  [INFO ] http-bio-9443-exec-1          com.cisco.ucs.vcplugin.service.UcsServiceBase                     getUcsHandle for uuid:
[2014-12-22 14:55:41.374] INFO  [INFO ] http-bio-9443-exec-1          org.springframework.flex.servlet.MessageBrokerHandlerAdapter      Channel endpoint secure-amf received request.
senthil andavan
Hi eswaran,
I have uploaded the logs..can you check
Thanks.
reswaran
Hi Senthil,
The log doesn’t show any issues. Can you please contact us through TAC or send your mail id for a webex session to debug the issue?
When you say “Launching KVM from UCSM GUI is working fine”, did you try it on the same machine where you launched vSphere web client?
Ravikumar
senthil andavan
Hi Ravikumar,
Yes, I tried to launch the KVM from same machine where I launched the Web Client.Do i need try to open from some other machine?
Senthil
vaibjain
Hope you do not have any popup blocker enabled in your browser as KVM url will be launched on a browser after the button click.
senthil andavan
Hi Vaibhav,
No, I did not enable any popup blocker
Senthil
reswaran
Please raise a TAC case to have a webex and debug the issue.
senthil andavan
Hi Ravikumar,
it is resolved. I am able to open the KVM now. the issue becasue of Java version. I reinstalled the Java 1.6 version and problem got resolved.
Thanks for your help..
Senthil
alexandre.molari
Community Member
not working (error at reg tool run) with PowerCLI 5.8 rel1. When will that be supported?
florian.schnelle
Community Member
When will vSphere 6 be supported?
cdhainfra
Also curious as to when vsphere 6 will be supported.
Matt
reswaran
The plugin is qualified with vSphere Web Client 6.0. Release notes and user guide was updated last week. I have fixed this document/blog too.
smith107
reswaran, Can I assume you've got this working in vSphere Web Client 6.0? After registering the UCS plugin successfully and restarting services on vSphere Web Client, I log back in and get faced with an error that it was unable to load a resource module from  /ucs-ui/locales/Ucsui-en_US.swf. If I continue, I see the UCS icon under Home, but clicking on it pops up more errors. Different browsers don't help.
prelhan
Hi David,
Yes, Plugin is working with vSphere Web Client 6.0
Please hit your url in below format.
https://vCenterIPAddres:9443/vsphere-client/
Note: Don't forget to add 9443 after vCenter Server IP
Hope this will help you.
Puneet
