on
		10-24-2013
		01:45 PM
 - edited on
		04-24-2020
		09:31 AM
 by
			dsoper
Previous Release Information:
Cisco UCS Manager Plugin is an extension for the vSphere Web Client. It enables virtualization administrators to view, manage and monitor various aspects of Cisco UCS physical infrastructure. The result is a single pane of glass for Virtual Center users to get both physical and virtual infrastructure information for a given hypervisor.
New Features in UCS Manager Plugin 2.0(3):
Supported vSphere Web Client Releases:
Refer to release notes and user guide for more details.
The issue is fixed and the updated registration tool 0.9.6 is available above for download.
Any word on this issue getting resolved in a newer version?
This is just the Registration tool refresh, We will be releasing new version of plugin soon with the fix for this.
Vaibhav
David,
Please share the web client logs.
Log Location:
Windows: C:\ProgramData\vmware\vSphere Web Client\serviceability\logs\vsphere_client_virgo.log
VCenter Appliance/Linux: /var/log/vmware/vsphere-client/logs/vsphere_client_virgo.log
Vaibhav
Hello Vaibhav, I sent you the log file via e-mail.
Thanks for your help!
Hi David,
I do see following stacktrace in the log:
[2014-09-09 14:57:59.920] [WARN ] http-bio-9443-exec-14 org.springframework.flex.core.DefaultExceptionLogger The following exception occurred during request processing by the BlazeDS MessageBroker and will be serialized back to the client: flex.messaging.MessageException: Cannot invoke method 'registerUcs'.
at flex.messaging.util.MethodMatcher.methodNotFound(MethodMatcher.java:387)
at flex.messaging.util.MethodMatcher.getMethod(MethodMatcher.java:172)
at flex.messaging.services.remoting.adapters.JavaAdapter.invoke(JavaAdapter.java:417)
at com.vmware.vise.messaging.remoting.JavaAdapterEx.invoke(JavaAdapterEx.java:30)
at flex.messaging.services.RemotingService.serviceMessage(RemotingService.java:183)
at flex.messaging.MessageBroker.routeMessageToService(MessageBroker.java:1400)
at flex.messaging.endpoints.AbstractEndpoint.serviceMessage(AbstractEndpoint.java:1011)
at flex.messaging.endpoints.AbstractEndpoint$$FastClassByCGLIB$$1a3ef066.invoke(<generated>)
at net.sf.cglib.proxy.MethodProxy.invoke(MethodProxy.java:149)
at org.springframework.aop.framework.Cglib2AopProxy$CglibMethodInvocation.invokeJoinpoint(Cglib2AopProxy.java:689)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
at org.springframework.flex.core.MessageInterceptionAdvice.invoke(MessageInterceptionAdvice.java:66)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.framework.adapter.ThrowsAdviceInterceptor.invoke(ThrowsAdviceInterceptor.java:124)
at org.springframework.aop.framework.Cglib2AopProxy$FixedChainStaticTargetInterceptor.intercept(Cglib2AopProxy.java:573)
at flex.messaging.endpoints.SecureAMFEndpoint$$EnhancerByCGLIB$$93eb7d8a.serviceMessage(<generated>)
at flex.messaging.endpoints.amf.MessageBrokerFilter.invoke(MessageBrokerFilter.java:103)
at flex.messaging.endpoints.amf.LegacyFilter.invoke(LegacyFilter.java:158)
at flex.messaging.endpoints.amf.SessionFilter.invoke(SessionFilter.java:44)
at flex.messaging.endpoints.amf.BatchProcessFilter.invoke(BatchProcessFilter.java:67)
at flex.messaging.endpoints.amf.SerializationFilter.invoke(SerializationFilter.java:166)
at flex.messaging.endpoints.BaseHTTPEndpoint.service(BaseHTTPEndpoint.java:291)
at flex.messaging.endpoints.SecureAMFEndpoint$$EnhancerByCGLIB$$93eb7d8a.service(<generated>)
at org.springframework.flex.servlet.MessageBrokerHandlerAdapter.handle(MessageBrokerHandlerAdapter.java:109)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:755)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.eclipse.virgo.web.tomcat.support.ApplicationNameTrackingValve.invoke(ApplicationNameTrackingValve.java:33)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
There is some thing off either with the web client installation or your setup. This error is coming from blazeDS (web client application). I will try to investigate further and keep you posted, meanwhile if you have any other setup, you can try the plugin there.
Vaibhav
Other option is to check with vmware on this issue. Are there any other plugins in this setup? Are they working fine?
Ravikumar
Hmm. Interesting. I will investigate on my side, but so far this vCenter installation has been pretty stable. I don't have other plug-ins installed. It is pretty vanilla.
I installed the latest patch a few weeks ago if I remember correctly and everything went well.
Thanks for the information; I'll check on the VMware side.
I have the same Issue David when installing the plugin to vCenter appliance 5.5.0.10200 Build 1891314. My plugin was working with version 0.96 but I got an error when I upgraded to 1.02. Looks like the problem was because I used HTTP instead of HTTS for the location of the plugin. The effect of this was the UCS icon never showed up.
I backed out by un-registering the plugin, then installed v0.96. I got exited when I saw that UCS icon show up. I upgraded to 1.02 using HTTPS for the plugin location and the UCS icon still was showing up in vCenter. I then proceed to register the UCSM but sadly got "Cannot invoke method 'registerUcs'."
Andre Alexanian
Did you try restarting the web client service?
Can you check the Host > summary page and see if the UCS portlet shows all the information correctly.
Vaibhav
Well, I did as aalexanian1 suggested and like by magic it now works. Thanks a lot for your help!
I sure did start the Web client service and when that didn't fix anything, I rebooted the vCenter appliance with same result.
Is there a way to truly scrub the UCS plugin from the vCenter because un-registering does not seem to bring back the vCenter to it's original state?
This morning, I un-registered 1.02, restarted the web client and installed 0.96. Magically my registered UCS Domain that I had previously registered 2 weeks ago was resurrected and is working. I then restarted the web services and proceeded to upgraded the plugin to 1.02. I had to restarted the web services because the web client would not work anymore and gave and error .
Sadly UCS plugin upgrade wiped my registered UCS Domain. I then proceed to register the UCSM but sadly got "Cannot invoke method 'registerUcs'."
Is there an update on the minimum permissions for KVM launch? We currently use Role-server-equipment for that via the web gui, but it's not updating in the vcenter web client.
I was able to successfully register the 1.02 plugin, and then register 2 pods. On 1 ESX host in UCS Pod B, opening a KVM console is successful. But with 2 ESX hosts that reside in UCS Pod A, I receive the following message when trying to open the KVM console:
Not able to launch KVM. The IP address to reach this server is not set.
I'm able to successfully connect to UCS Manager on Pod A, as well as open KVM consoles to those 2 blades. Any idea what this message means?
