Jeffrey Foster
The following Plugin for VMware vSphere Web Client is available for download from Cisco.com:
Cisco UCS Manager Plugin Release 2.0.3 for VMware vSphere Web Client:
Downloads:
Documentation Links:
External customers - For any issues, contact Cisco TAC (highly recommended for quick resolution) or add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities. Send your suggestions for new features/enhancements to ucs-vmw-plugins@cisco.com.
Internal (Cisco) customers and employees - Contact us at ucs-vcplugin@cisco.com for support questions and ucs-vmw-plugins@cisco.com for roadmap questions, new feature requests and feedback.
Cisco UCS Manager Plugin Release 1.0.1 for VMware vCenter Orchestrator:
Downloads:
Internal (Cisco) customers and employees - Contact us at ucs-vco@cisco.com for support questions and ucs-vmw-plugins@cisco.com for roadmap questions, new feature requests and feedback.
Cisco UCS Central Plugin Release 1.0 for VMware vRealize Orchestrator:
Downloads:
bhuttah01
Community Member
the plugin for UCS Management Centre is at ver 1.1(1)
hi guys,
I am trying to install the latest version of the UCS Manager either the registration tools or copying it to the plugging folder is not working.
I don't have any error in both method (I see the file in both places as stated in other posts)
I am at lost to get this on, to deploy the latest firmware to our 130 hosts servers.
any magic trick would be appreciated.
This is just to complicated. a simple installation tools that's work directly on the Vcenter would be very appreciated.
Steph
vaibjain
Hi Steph,
Please let us know the version of vCenter/Web client and UCSM Plugin. Check web client logs and see if there is any error logged, also attach the web client logs here so that we can take a look.
-Vaibhav
Good morning Vaibhav,
here is the info you requested:
Vcenter ,Version 5.1.0 build 2306353
Vsphere web client Version 5.1.0 build 2301183
Flash player Win 17,0,0169
Java version 8 update 45 ( on workstation where the plugin is being run)
Java version 7  Update 40 (On Vcenter where plugin is installed)
only version of plugin that updated is 0.9(2) going to version 1.1.1
we tried with a web server and the registration tool the deployment work but the plugin never showed up any where.
tried also the method where you copy the plugin directly on the Vcenter servers (we have 4 btw) never showed up either.
here is an extract of the web client logs.
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.282] [INFO ]  Connection(22)-10.232.98.45  <DE0000I> Installing bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'.
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.297] [INFO ]  Connection(22)-10.232.98.45  <DE0001I> Installed bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'.
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.313] [INFO ]  Connection(22)-10.232.98.45  <DE0004I> Starting bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'.
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.609] [ERROR] region-dm-4                   <AG0000E> Application context creation failure for bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'UcsRegistrationService': Initialization of bean failed; nested exception is org.springframework.beans.TypeMismatchException: Failed to convert property value of type 'java.util.LinkedHashSet' to required type 'java.lang.Class[]' for property 'interfaces'; nested exception is java.lang.IllegalArgumentException: Error loading class [com.cisco.ucs.vcplugin.service.UcsRegistrationService]: problem with class file or dependent class.
and after looking at it I guess Java Strikes again.  I have added the full log in attachment.
My thought goes to a Java issue Again.....
What do you think?
Steph
full log starting here:
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:563)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2015/05/22 08:31:48 | Caused by: org.springframework.beans.TypeMismatchException: Failed to convert property value of type 'java.util.LinkedHashSet' to required type 'java.lang.Class[]' for property 'interfaces'; nested exception is java.lang.IllegalArgumentException: Error loading class [com.cisco.ucs.vcplugin.service.UcsRegistrationService]: problem with class file or dependent class.
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.BeanWrapperImpl.convertIfNecessary(BeanWrapperImpl.java:467)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:499)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.BeanWrapperImpl.convertForProperty(BeanWrapperImpl.java:493)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.convertForProperty(AbstractAutowireCapableBeanFactory.java:1371)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1330)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1086)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  ... 16 common frames omitted
INFO   | jvm 1    | 2015/05/22 08:31:48 | Caused by: java.lang.IllegalArgumentException: Error loading class [com.cisco.ucs.vcplugin.service.UcsRegistrationService]: problem with class file or dependent class.
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.util.ClassUtils.resolveClassName(ClassUtils.java:296)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.propertyeditors.ClassEditor.setAsText(ClassEditor.java:63)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.TypeConverterDelegate.doConvertTextValue(TypeConverterDelegate.java:416)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.TypeConverterDelegate.doConvertValue(TypeConverterDelegate.java:388)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:157)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:111)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.TypeConverterDelegate.convertToTypedArray(TypeConverterDelegate.java:427)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.TypeConverterDelegate.convertIfNecessary(TypeConverterDelegate.java:169)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.beans.BeanWrapperImpl.convertIfNecessary(BeanWrapperImpl.java:447)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  ... 22 common frames omitted
INFO   | jvm 1    | 2015/05/22 08:31:48 | Caused by: java.lang.UnsupportedClassVersionError: com/cisco/ucs/vcplugin/service/UcsRegistrationService : Unsupported major.minor version 51.0
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at java.lang.ClassLoader.defineClass1(Native Method)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at java.lang.ClassLoader.defineClassCond(Unknown Source)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at java.lang.ClassLoader.defineClass(Unknown Source)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.defineClass(KernelBundleClassLoader.java:238)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:601)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:567)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:490)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:478)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:458)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:134)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at java.lang.ClassLoader.loadClass(Unknown Source)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.osgi.util.BundleDelegatingClassLoader.findClass(BundleDelegatingClassLoader.java:99)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.osgi.util.BundleDelegatingClassLoader.loadClass(BundleDelegatingClassLoader.java:156)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.util.ClassUtils.forName(ClassUtils.java:257)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  at org.springframework.util.ClassUtils.resolveClassName(ClassUtils.java:290)
INFO   | jvm 1    | 2015/05/22 08:31:48 |  ... 30 common frames omitted
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.609] [ERROR] start-signalling-1            <DE0006E> Start failed for bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'UcsRegistrationService': Initialization of bean failed; nested exception is org.springframework.beans.TypeMismatchException: Failed to convert property value of type 'java.util.LinkedHashSet' to required type 'java.lang.Class[]' for property 'interfaces'; nested exception is java.lang.IllegalArgumentException: Error loading class [com.cisco.ucs.vcplugin.service.UcsRegistrationService]: problem with class file or dependent class.
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.672] [INFO ] start-signalling-1            <DE0010I> Stopping bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'.
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.672] [INFO ] start-signalling-1            <DE0011I> Stopped bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'.
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.687] [INFO ]  Connection(22)-10.232.98.45  <DE0013I> Uninstalling bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'.
INFO   | jvm 1    | 2015/05/22 08:31:48 | [2015-05-22 08:31:48.687] [INFO ]  Connection(22)-10.232.98.45  <DE0014I> Uninstalled bundle 'com.cisco.ucs.vcplugin.service' version '1.1.1'.
any news?
vaibjain
Steph,
We tried to reproduce the issue on our side with java8, but did not get this reproduced. I will drop you an email, I would like to troubleshoot this issue over webex.
Vaibhav
ok when ever your ready
vaibjain
Steph,
We support vCenter 5.1 or higher but web client version should be 5.5. Please refer the System Requirement section in Release Notes.
Vaibhav
Arithor
Community Member
I´m trying to install the plugin with the registration tool but I get that the zip file is not valid.
I downloaded both version 1.1.1 and 1.0.2 both zip files don´t work. Download link. Cisco Systems
Vmware vCenter 5.5 Build 2105955-20140901
Vmware VMware PowerCLI 5.8 Release 1
Anyone idea what is wrong?
Ari
vaibjain
how does your plugin url look like? The registration tool gives such errors mostly when either the link is not pointing to correct zip file or the location is not reachable from the machine you are running Registration Tool. Check the plugin zip file as well it should only have following files after unzipping:
plugin-package.xml
plugins/ucs-vcplugin-service.jar
plugins/ucs-vcplugin-ui.war
plugins/vim25.jar
Vaibhav
Arithor
Community Member
I can access the file from the server in browser, so I can access the file.
Yes the file contains.
plugin-package.xml
plugins/vim25.jar
Regards Ari
vaibjain
Do you see any error message in web client logs? I am also assuming that your web client version is also same as vcenter. Please upload the web client logs as well so that i can do preliminary investigation as well.
Are you hosting the plugin over http or https?
Vaibhav
Arithor
Community Member
No there are no errors in the web client logs. I´m hosting the plugin over http
Regards Ari
dsavilonis
Community Member
Is there any plan to do integration with standalone C-series servers? This would have a lot of value as it's otherwise it's really hard to map virtual to physical servers and the management console. Just having an automatically generated link to the management console in vmware would be really valuable.
tdewanjee
Community Member
The Plug-in is not working for Vcenter 5.5 and vSphere 6.0. Is it ony supportable in Vcenter 5.1 ?
