Jeffrey Foster
We are pleased to announce the release of Cisco UCS PowerTool Suite version 2.4.1.
Cisco UCS PowerTool suite is a set of PowerShell modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central that helps in configuration and management of Cisco UCS domains and solutions.
Key Features in Release 2.4.1
  • Support for new features in Cisco IMC Release 3.1(3a)
  • Support for new features in Cisco UCSM Release 3.2(3)
  • Updated cmdletSet-ImcHuuFirmwareUpdaterwith new parameters.
  • Updated catalog rules for M5 Servers.
Key Features in Release 2.3.1
  • Support for new features in Cisco IMC Release 3.1(1d)
  • Support for new features in Cisco UCS Central Release 2.0(1b)
  • Support for new features in Cisco UCSM Release 3.2(1d)
  • Updated cmdletAdd-UcsCentralServiceProfileFromTemplateto create Service profile with service profile template
  • Added cmdletGet-UcsCentralPolicyUsageto provide support to fetch policy details for any managed object.
Key Features in Release 2.2.1
  • Support for new features in Cisco IMC Release 3.0(1c) and 3.0(2b)
  • Support to launch the UCS Manager HTML GUI automatic login
  • Support to specify the JSON file as input for uploading the hardware profile to HCL Tool
  • Support to collect advisories for the hardware profile in HCL Tool cmdlet
  • Security enhancement to HCL Tool cmdlets
Your scripts written using PowerTool 1.x will break due to module name changes.
The following table lists the module name changes in this release:
Previous Module Name
New Module Name
CiscoUcsCentralPS
Cisco.UCSCentral
CiscoImcPS
Cisco.IMC
CiscoUcsPS
Cisco.UCSManager
Installer download (from cisco.com):
Module download (from Powershell Gallery):
  • Cisco.UCSManager
             https://www.powershellgallery.com/packages/Cisco.UCSManager/2.4.1.3
  • Cisco.IMC
               https://www.powershellgallery.com/packages/Cisco.IMC/2.4.1.3
  • Cisco.UCSCentral
              https://www.powershellgallery.com/packages/Cisco.UCSCentral/2.4.1.3
  • Cisco.UCS.DesiredStateConfiguration
               https://www.powershellgallery.com/packages/Cisco.UCS.DesiredStateConfiguration/2.4.1.3
Documentation:
Reference: Cisco UCS PowerTool Command Reference for Cisco UCS Manager
External customers - For any queries/feedback on PowerTool, contact Cisco TAC or ucs-powertool@cisco.com or add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities
We are also on Slack - slack requires registration, but the cisco-ucs-powertool channel on powershell team is open invitation to anyone to register here. Once you join the powershell slack team you can join cisco-ucs-powertool channel here
Internal (Cisco) customers and employees - Contact us at ucs-powertool@cisco.com for support questions and ask-ucs-tme@cisco.com or ask-ucs-pm@cisco.com for roadmap questions and feedback.
reswaran
In the meantime, you can enable the GUI logs for UCS central using the following option
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/UCS_Central/powertools/user_guide/ucsc_pwrtool_bk.html#pgfId-446548
and then run ConvertTo-UcsCentralCmdlet which will generate the cmdlets for the operations you perform in GUI.
Ravikumar
thomsonac
Level 4
Level 4
After the last couple of firmware updates, I get an error that the flexflash controller is running old firmware.  A simple reset of the flash controller resolves the error.  I'm trying to achieve the reset via UCSC; could you help find the right set of cmdlets to achieve that?
I've tried some combinations of cmdlets after the below but not having much luck.  The noun I think I'm looking for is "UcsCentralStorageFlexFlashController" but there doesn't appear to be cmdlets associated with it?  Get-ucscentralstoragecontroller seems to be only be related to the spinning disks.
Get-UcsCentralBlade -dn <PROFILE>.pndn | Get-UcsCentralComputeBoard |
I appreciate the help, thanks.
reswaran
Hi Alex,
We will look into it and get back to you.
-Ravikumar
nveda
Hi Alex,
The MO that you are referring to was added in UCS Central 1.3.1. We do not have corresponding cmdlet in UCS Central release available on communities. We will support it in the upcoming version of UCS Central.
We do have some generic cmdlets which can be used.
Here is an example –
Get-UcsCentralChassis -Id 1 | Get-UcsCentralBlade -SlotId 1 | Get-UcsCentralComputeBoard | Get-UcsCentralMo -ClassId StorageFlexFlashController | Set-UcsCentralMo -PropertyMap @{Configu
redMode="mirror"; AdminSlotNumber="NA"; OperatingMode="mirror"; operationRequest="reset"}
Keep your questions/queries coming.
Thank you,
Nitin
thomsonac
Level 4
Level 4
Thanks for the response Nitin.
The command ran successfully but did not clear the alert.  The output of the command was:
WARNING: Attempt to set non-existent property 'operationRequest' in class 'StorageFlexFlashController'.
WARNING: Attempt to set non-existent property 'OperatingMode' in class 'StorageFlexFlashController'.
WARNING: Attempt to set non-existent property 'ConfiguredMode' in class 'StorageFlexFlashController'.
WARNING: Attempt to set non-existent property 'AdminSlotNumber' in class 'StorageFlexFlashController'.
ControllerHealth    : FFCH_ERROR_OLD_FIRMWARE_RUNNING
ControllerState     : FFC_FAILED
FlexFlashType       : FX3S
LocationDn          :
Model               : FX3S
OperQualifierReason :
OperState           : degraded
Operability         : operable
PciAddr             :
PciSlot             : N/A
Perf                : unknown
PhysicalDriveCount  : 0
Power               : unknown
Presence            : equipped
PrimarySlotNumber   : 0
RaidSyncSupport     : yes
ReadErrorThreshold  : 0
Revision            : 0
Serial              : NA
Thermal             : unknown
Type                : SD
Vendor              : Cypress
VirtualDriveCount   : 0
Voltage             : unknown
WriteErrorThreshold : 0
Dn                  : compute/sys-1010/chassis-1/blade-2/board/storage-flexflash-1
Rn                  : storage-flexflash-1
Status              : modified
XtraProperty        : {[AdminSlotNumber, NA], [ConfiguredMode, mirror], [FirmwareVersion, ], [HasError, error]...}
reswaran
Alex, what is the version of UCS central that you are running?
thomsonac
Level 4
Level 4
1.3(1b)
reswaran
Was the alert getting cleared when you perform the reset action from UCS central GUI?
thomsonac
Level 4
Level 4
I've never found a way to reset the flex flash controller through the UCSC GUI
sumbr
Level 4
Level 4
Hi Raphael,
Currently there are no cmdlets In the PowerTool for getting the SEL and Sensor information.
Sumanth
James Hester
Any updates coming to this to add features related to the 1.4 release of UCS Central?
reswaran
Yes James. PowerTool 2.0 will be released by early March. There will be single powertool installer containing all 3 modules (IMC, UCSM and UCS Central) and UCS central module will have cmdlets for the features in the latest 1.4 release.
James Hester
That's probably the best possible answer you could have given - thanks!
janegilring
Community Member
Congratulations on the 2.0.1 release, the Cisco.UCS.DesiredStateConfiguration module looks very promising.
A suggestion for future releases: Could you consider releasing the Cisco UCS PowerTool Suite on the PowerShell Gallery? That would make it more convenient for users to install and update the modules.
Examples:
# First time install
Install-Module -Name CiscoUcsPS
# Update the module when it`s already installed
Update-Module -Name CiscoUcsPS
More information:
PowerShell Gallery            | GettingStarted
nveda
Thank you Jan Egil Ring for your suggestion. Keep them coming.
We will consider this in future PowerTool Suite releases.
Thank you,
Nitin
