qiayu
Workflow Name
Create APIC Tenant with Contract
Description
This workflow creates a new tenant in a specified APIC cluster along with the necessary network configurations to run a simple web service demonstration. Once the workflow is completed you can put a demo 'web server' vm in the 'server' port group, and a 'web client' vm in the 'client' port group and test icmp and http - all other protocols will fail between the 2 vms.
Components
  • APIC
  • VMware vCenter
Versions Tested
  • UCSD: 5.1.0.0
  • APIC: 1.0(1k)
  • vCenter 5.1
  • For APIC 1.0(2j): disable https and enable http. In the ucsd create a credential policy for your apic account that uses http.
User Inputs:
  1. APIC cluster
  2. Tenant Name
  3. Application Profile Name
  4. Server EPG Name
  5. Client EPG Name
  6. Network Name
  7. Server BD Name
  8. Server BD GW
  9. Server BD subnet prefix
  10. Client BD Name
  11. Client BD GW
  12. Client BD subnet prefix
Workflow Tasks:
  1. Create APIC tenant
  2. Create application profile
  3. Create network
  4. Create ‘server’ BD
  5. Create BD subnet
  6. Create ‘client’ BD
  7. Create BD subnet – for the second BD
  8. Create ‘server’ EPG
  9. Add a domain to the ‘server’ EPG
  10. Create ‘client’ EPG
  11. Add a domain the ‘client’ EPG
  12. Create a contract
  13. Create contract subject
  14. Add contract to ‘server’ EPG
  15. Add contract to ‘client’ EPG
  16. Create security policy filter
  17. Create filter rule for icmp
  18. Create filter rule for http
  19. Add filter to contract subject
mtimm
For APIC version 1.0(2m) there should be no need to disable https.  1.0(2j) had HTTPS/TLSv1.1/TLSv1.2 support only on the APIC.  1.0(2m) adds TLSv1.0 back so UCSD should be able to communicate just fine over https again.
